RT3 (Can Bus) 6.63
ase
RT3 (Can Bus) 6.63
Hi everyone—I’ve got an RT3 (CAN bus) version 6.63 on my Peugeot 607 with French language, and I need to switch it to English. I no longer have the original CD. Could someone help me by sharing the correct English language ISO for 6.63, or point me to a trusted download? Thanks in advance!
- x 8087
Re: RT3 (Can Bus) 6.63
Hi and welcome,
Unfortunately we do not currently have access to the Stellantis database to enable us to help you. If you look at this thread you will see that there are a number of similar issues outstanding and there may be solutions to be found elsewhere, maybe on the Peugeot Owners Forum for example. If you find a solution it would be very helpful to post it back here for other member's benefit. Good luck.
- x 1938
I've found a source for the RT3 firmwares and I'll send you a link to it in a PM.
I've downloaded it seemingly successfully although I haven't tested anything.
Usual disclaimers, use at own risk, etc.
407coupe2006
Hi, Paul-R, Can you share the link with me? I'd like to change language on my car too. My is RT3 v.6.63
- x 1938
@407coupe2006, check your PM.
Mirzac5
I have version 6.51 and I need 6.63
can you also send me the download link.
does it also fit citroen c5?
- x 1938
@Mirzac5 Check your PMs. Use at your own risk,etc.
Will it fit a Citroen C5? I presume that is the car which you have found is fitted with 6.51 so yes. Probably. I have no direct experience with Facelift model.
SunflowerSamurai
- New User
Hi everyone,
I need to change the system display language from German to English on my Citroën C4 Picasso (2007).
My unit details from the diagnostic menu :
Head Unit: RT3 CAN-bus
Soft-Version Steuerge: 6.63
Display Soft-Version: C30CE0C35
Could someone please share or point me toward a working ISO image for the RT3 CAN v6.63 software disc?
Thanks in advance for the help!
- x 1938
Check your PM.
