Hi All,
Just to share my experience last week and guessing some have had similar moments also? I was able to drive for about 100miles then car suddenly hesitates/judders in gears 2 and 3 at low revs. No fault codes but P2463 came about from time to time. When using aircon, I can feel the engine is somehow sluggish. No engine light but service light turns on and off whilst driving (twice). I was able to get home though. DPF accumulating soot fairly quick after cleaning. Noticed some carbon build up at the back of the turbo. I have not checked the egr yet. Would appreciate some pointers please from experienced owners. Thanks a bunch.
C4 Picasso judders/ hesitates when pulling
- x 7789
Re: C4 Picasso judders/ hesitates when pulling
A read through this thread may give you some pointers: viewtopic.php?p=797001#p797001
PaulC5
- x 569
P2463 suggests the dpf is blocked. What year, how many miles, has the dpf fluid been topped up ? Has the fuel filter been changed ? After cleaning the dpf was it as new or still blocked and did you tell the car it had been cleaned ?
C4Picasso
- x 5
2016. P2463 was temporary. Checked DPF diff pressure when cleaned (5-6mbar) but slowly crept up to to 29mbar (no error codes yet). Fuel Filter was changed 2 months ago. The last point, i did not tell the car dpf has been cleaned.
C4Picasso
- x 5
2016. P2463 was temporary. Checked DPF diff pressure when cleaned (5-6mbar) but slowly crept up to to 29mbar (no error codes yet). Fuel Filter was changed 2 months ago. The last point, i did not tell the car dpf has been cleaned. Oooops!
Also dpf countdown is ticking with approx. 5k left to spare
C4Picasso
- x 5
Did another clean today (no forced regen) and achieved diff pressure of 4mbar, however, I discovered my obd device (topdon artidiag800bt) can not reset the dpf.
