Hi all,
2010 Clio dci
I have an issue where my head unit, clock/temp display and cigarette lighter have all lost power when they were working fine previously. I believe it happened since I changed the battery.
I have pulled and checked continuity in every fuse below the steering wheel, pulled and checked every fuse in the engine bay fuse box and all are fine. I've tried a different head unit just in case also but I am sure it's a power supply issue, I just don't know what else to check.
I am hoping somebody might be able to point to something I am missing. Any help or advice is much appreciated.
Thanks in advance!
2010 Clio Head unit, clock display and cigarette lighter have all lost power
Yewboy69
- x 3
- x 8127
Re: 2010 Clio Head unit, clock display and cigarette lighter have all lost power
It would seem there are two fuses involved so have a look at this which also has some suggestions about the problem and see if it helps:
https://www.startmycar.com/gb/renault/c ... radio-fuse
