Fuse Box 2 Location? Power Steering Fault
cdawgx
Unread post by cdawgx »
Hiya, I've got a 2012 207cc
The manual suggests there's a master-fuse MF10 for power steering located in 'fuse box 2' - does anyone know where this is? I've lifted the main engine fuse box to reveal MF1-8 in a strip along the front, but can't find the remaining three.
I'm getting fault codes C1415 and P0606 with a power assisted steering fault. Some have suggested the motor or rack might need replacing, but I thought I'd try this master-fuse first (F7 was fine but have replaced anyway).
x 8085
Re: Fuse Box 2 Location? Power Steering Fault
The only references I can find to Fuse Box 2 say that only a Peugeot dealer should access that fuse box. No doubt that is why it is hard to determine the location. I suspect it will be under the engine fuse box but only guessing!! :)
x 1450
Unread post by xantia_v6 »
I may be able to find something, can you give the ORGA (RP) number of your car, and which engine/transmission are fitted?
x 1450
Having a guess at the specification of your car, I think that the Steering Unit is supplied through MF6 (battery supply) and F1 (switched ignition).
