Hi
I am in the process of buying a used 2019 Citroen C3 puretech 82 s&s feel in spain (I am at home in England and will aquire the car in sept) my question is how can I find out if the car has inbuilt sat nav as it is one of the reasons I'm buying the CAR.
TIA
Gary
C3 built in sat nav
- x 8073
Re: C3 built I sat nav
If you contact a Citroen dealer with the VIN they will be able to tell you, ask for a copy of the build sheet for future reference.
WorTHy57
I will give that a go tomorrow
thanks for your reply
PaulC5
- x 669
Re: C3 built in sat nav
If buying the car remotely without checking it you need to make sure it has been dealer serviced and the timing belt changed since these run in oil and are known to fail.
WorTHy57
Hi PaulC5
I know the car was serviced at a Citroen garage last week (I have seen and driven the car before I came home to England but I didn't check the sat nav) but I will ask about the timing belt...Thanks
