Replaced "Turbo pressure valve" - does it require calibration ?
gibman
Unread post by gibman »
hi.
1.6 bluehdi, 120hp.
Citroen C4 gr. picasso, 2015.
I have replaced the turbocharger pressure valve with this one:
https://nap.dk/ladetryksstyring-turbola ... 02300.04.0
Although now I have a very rough idle.
If I put back the original part then IDLE is ok again.
fun fact: the original part on the engine is a Pierburg branded valve also.
Maybe it needs calibration in diagbox ?
If yes. Is this doable ?
I should mention I have a working diagbox setup.
more context;
I replaced the pressure valve as I had a periodic issue with these faultcodes:
P1496 00
P2563 00
regards
gibman
x 8091
Re: Replaced "Turbo pressure valve" - does it require calibration ?
I'm afraid I have not found any information on this but hopefully someone who knows will see your post and let you know! Sorry! :)
x 1454
Unread post by xantia_v6 »
I am fairly sure that the valve is continuously calibrated by the ECU measuring the boost pressure, no manual calibration required.
I suspect that your new valve is incompatible or faulty. My understanding is that on HDI engines, there is no boost at idle, and no vacuum from the control valve at idle.
