Thanks in advance!
C5 II Driver’s door lock internal diagram needed
drumvlado
Hello. In a complete loss of reason, after successfully installing Cirocco from C5 aircross, I decided to upgrade the BSI to one from a later X7 (BSI04EV), but as the first generation on C5s uses older style (Xarra/Xantia) door locks I have some minor issues with rewiring. Is there such document that explains the design of the locks, similar to the different module presentations? I really need to know what pin 4 does
Thanks in advance!
Thanks in advance!
- x 8084
Re: C5 II Driver’s door lock internal diagram needed
Can you clarify which car you are installing this on?
aspire_helen
- x 80
The following are the 6 pins on the C5 Mk1 rear door
Connector
Pin Wire Colour
1 Microswitch – door latch status White
2 Common return for both microswitches and vehicle earth Green/Yellow
3 Microswitch – childlock status White
4 Common return for both motor actuators White
5 Motor actuator - external handle enable/disable White
6 Motor actuator - central locking White
Connector
Pin Wire Colour
