Which Diagbox to buy?
Vikis
Unread post by Vikis »
Hello, could you please give me a link for a full chip reliable Diagbox? I will work on Citroen and Peugeot up to 2015-2016. I found a lot of links, but everywhere I can find bad reviews. Maybe someone bought it recently and can help me? It doesn't matter if it's eBay, AliExpress, UK, or Europe. Thank you.
x 8156
Re: Which Diagbox to buy?
Contact Jim at Easy Diagnostics and he will advise, this is a link to the scheme we had running with him, as far as I know it is still valid.:viewtopic.php?p=575129#p575129 :)
Vikis
Thank you. I have contacted Jim at Easy Diagnostics, he recommended VXDiag, because I'm located in EU. Does anybody tried VXDiag? How is it compared to Diagbox full chip clone? Which one would you recommend to use? Prices are nearly the same, so I'm not sure what to buy
Kees
x 150
Unread post by Kees »
The Diagbox from AliExpress Full chip works 100% good for all types, but you need a software version 9.XX for all types, and look for "no vm"
Vikis
What do you think about these two? Which one should I buy? Or maybe someone bought and can help me with the link.
https://a.aliexpress.com/_ExpBX6O
https://www.aliexpress.com/item/1005007543029231.html
Kees
x 150
I should go for this one, this one is used by myself.
Mihael_M
x 37
Unread post by Mihael_M »
Diagbox is software and Lexia 3 is hardware.I also bought like Kees, it's Lexia 3 Full chip Led plus. With blue connector. In addition, Diagbox software is needed. They can work with new and older cars.I use 9.85, 9.186 and Free Robert version, all 64 bit and no WM.
Kees
x 150
This will it more complicated to choose!
Just buy the one i advice, because if you buy it, you get the hardware, cabels and software all in one box.
