Front disk + bleeding
user_3150
New User
Unread post by user_3150 »
Morning I'm changing the front disk's and pad's and bleeding the brakes today. It look's easy enough but any pointer's or advice would be helpful and appreciated.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
You may or may not find the discs almost impossible to remove. When I did mine, the o/s fell off after removing the screws, but the n/s needed persuading with a lump hammer. Before mounting the new disc, clean off any rust, otherwise they might not run true. When bleeding the brakes, go gently with a RING spanner on the bleed nipples. I find they open easier if I give them a quick tap with a hammer, end on.
user_3150
New User
cheers john all done now. Brakes excellently had loads of air in all 4 corners I wonder if the resovoir was allowed to run low anyway she is a peach to drive now all is sorted and all in cost less than £200 quid (6 spheres and front disks + pads)
