Citroen Fixing screws
Gambit
x 9
Unread post by Gambit »
Hi
Im trying to remove the inner door panel on a 2015 C3
Ive got the 3 torx screws out of the edge, split the pull handle and removed the window switch.
Does the open lever have a removable trim?
What are the screws holding the pull handel, they look like they have 4 small holes in the head .
Help please
x 5679
Re: Citroen Fixing screws
A photo of the screw head would help greatly.
I had a bit of a look here but nothing jumps out at me.
With the minor exception of the 'snake eyes' head, now I know what that tool in my kit is for.
Edit:
Found these:-
x 1952
Unread post by Paul-R »
x 5679
Gambit
x 9
would be nearest ive seen except they are in the bottom of a recess and the head diameter is only 6-8 mm
Gambit
x 9
Duhh, does help if you look properly!!!
The 4 dimples I could see are actually 2 alphabetical letters and 8.8 the tensile strength, they are in fact washered hexagon bolts which my dewalt socket would just go on.
