C5 PH1 Suspension computer
Websster
Unread post by Websster »
Hi guys,
Is it possible to change the height of a C5 2003 PH1 2.016V?
I've got a lexia interface, can read out the faults but i can't change anything of the suspension computer.
Thanks in advance!
Greetings
Pieter
x 1056
Re: C5 PH1 Suspension computer
Unread post by wheeler »
Do you mean alter the ride height? only very small amounts. You set the ride height by rotating the clamp on the anti roll bars that has the linkage for the height sensor. Fine adjustments are the done with Lexia
Clogzz
x 40
Unread post by Clogzz »
What happens if you try the ride height buttons at bottom left ?
x 1944
Unread post by Paul-R »
The suspension will alter to whatever setting you choose. When you then drive off the suspension will return to its normal height as you go above a certain speed.
What are you trying to do? Raise or lower? For what purpose?
x 1056
Yeah wasn't sure if the OP meant just move the suspension up & down or actually set the ride height?
