if it helps it keeps throwing the code P0100
Citroen C5 X7 2,2 HDI cone filter
VeloDK
hi guys i recenty fitted a cone filter to my C5 and i was wondering if anybody knows if you could take the mass air flow sensor from a 2,7 HDI or 3,0 HDI so that it stops creating fault codes?
- x 8151
Re: Citroen C5 X7 2,2 HDI cone filter
We cannot comment on that type of modification as it takes the vehicle out of spec. However this link to the full description of that generic fault code might help you in working it out. viewtopic.php?p=811473#p811473
- x 1056
Is this fault code on happened as soon as you changed the air filter?
PaulC5
- x 701
If it clears when you put the original air filter back then the cone filter may be the culprit, possibly it is letting too much air through. You could also check the MAF wiring has not been damaged.
