Vacuum in diesel tank 2009 Citroen belingo 16 hdi
Kev S
New User
Unread post by Kev S »
Hi, Just changed the fuel line pressure sensor and egr valve and vacuum pump while I was on with it. Now it won't bleed and manipulation of the bleed bulb results in no fuel but a vacuum in the fuel tank visible when removing the fuel filler cap. Doe's the tank need to come off to replace the fuel tank breather pipe ? Or what is required to carry out the task, what else could it be that's worth replacing at same time. Any part numbers appreciated. Thanks.
x 8147
Re: Vacuum in diesel tank 2009 Citroen belingo 16 hdi
Hi Kev and welcome to the forum.
I think you may find a browse through this thread on the Berlingo forum helpful:
https://www.berlingoforum.com/thread-23795.html
