I have a 2020 Rifter right hand drive UK spec.
I am installing the genuine Peugeot trailer socket wiring kit 1680089380. The instruction note 4070 seems to be mostly correct. However, the instructions for a fuse block which is part of the kit appear to be incorrect/incomplete. On page 20 figure 35 and page 21 figure 36, the fuse block is shown supplied with power by a white cable/connector 'E' which is part of the additional front loom. The other end of this white cable is shown on page 15 figure 27 and page 16 figure 28 as cable/connector 'H' and this should plug into a connector which according to the installation note is located under the nearside from seat. However, no such connector there seems to exist.
I would be very grateful for any help with locating the elusive connector. I wonder if there is a difference between left hand drive and right hand drive cars for this connector ?
Thank you.
Tony Erwood
Peugeot Rifter genuine trailer wiring instructions error
TonyLunna
- x 8122
Re: Peugeot Rifter genuine trailer wiring instructions error
I think you may be right about LHD and RHD being different in that the connector may be under the driver's seat on RHD models, ie in the same geographical position as a lhd nearside seat ?
TonyLunna
Sorry I should have said in my original post that I also looked under the drivers seat, but alas no such connector there.mickthemaverick wrote: 12 Jul 2025, 16:40 I think you may be right about LHD and RHD being different in that the connector may be under the driver's seat on RHD models, ie in the same geographical position as a lhd nearside seat ?![]()
- x 8122
In that case your best course of action may be to identify the function of each wire in the white plug from the kit diagram and then manually install wires to connect each one to the right circuit. Good luck!
- x 1052
Are you able to post up said instructions?
TonyLunna
I have the instructions as a pdf file but this forum doesn't seem to allow the attachment of pdf files, only gif files and I haven't found a way to convert to that file type. However, here is a link to where the file can be downloaded from. Hope that works:
https://eshop-peugeot.cz/gb/index.php?c ... chment=429
