I'm in the process of telecoding the abs module on my 508 rxh .It's my understanding that I can't telecode any module using Diagbox 9.80(what i'm using now to scan and erase code on the car ) because it requires the PSA Verified Network.
I have downloaded Diagbox 7.83 and it should let me telecode without needing the connection to the PSA servers and network.
I have created a MV with win XP SP3(32Bit),I have the 7.83 version of diagbox(having some trouble installing it tho) ,but I don't have the driver to let the os reconize my lexia 3 adapert.
I can't find the driver anywhere on the internet (maybe i'm blind)..Can someone help me with a link ? thanks.
Lexia 3 Win XP Driver ?
- x 1459
Re: Lexia 3 Win XP Driver ?
The driver is part of the Lexia installation, so should be installed automatically. I think your problem may be that the driver is installed but is not loading because it is not recognising a USB port on the VM. It sometimes struggles to recognise even real USB ports on real XP installations,
OnlinePaul-R
- x 1938
Doesn't it have to be the Pro version of XP? The OP doesn't state what's in use.
- x 1459
It doesn't need to be pro, and for Diagbox it doesn't need to be 32 bit. I haven't run diagbox in a VM, so can't be much help.
If the hardware can run XP or Win7 natively, you could swap in a different SSD drive and install on that.
OnlinePaul-R
- x 1938
That may be the case for later versions but I'm sure that I remember when installing my ver 7.xx that it had to be 32 bit in order to run the 16 bit Lexia and PP2000 modules for pre 2005 cars. I thought I had to get a Pro version of Win 7 as well but could be wrong.
- x 1459
The OP in this topic requires only Diagbox for his vehicle, so 64 bit is ok for him.
