Grand C4 Picasso II Dash Cam Install Video
mideos
Unread post by mideos »
This is a dash cam installation video I made for the Grand Picasso.
I hope it can be of some help.
x 8165
Re: Grand C4 Picasso II Dash Cam Install Video
Thanks for the video which may help some members, however I would add that you should wear gloves when dealing with so many potentially sharp trim panel edges and secondly the final power connection should be at least checked if not done by an auto electrician unless you are qualified to deal with it in order to be sure that you don't overload a circuit. :)
mideos
This is the first time I've received such advice. That's why I feel good.👍
I'm the type of person who can't wear gloves because they're too stuffy, so I had to do it with my bare hands. Please understand. And I finished checking the fuse box with a tester. I couldn't take pictures at the end because I was exhausted from the heat.😄
