Grand C4 Picasso II Instrument Cluster Replacement Video
mideos
Unread post by mideos »
This is a video of Grand Picasso's instrument panel replacement.
There are already great videos, but I've made them in my own way.
Photographing model: iPhone 16PRO
x 8073
Re: Grand C4 Picasso Instrument Cluster Replacement Video
A reasonable video but I would add the following tips:
1) Before removing the trim panels tape a protective film over the screen with masking tape if you intend to reuse it. If not protect the new one before fitting it.
2) After refitting the plugs in the back of the new/replaced screen lay it back and power up to test it, if you have not plugged it in correctly you don't want to go through the whole refit and remove cycle.
3) Use a magnetic screwdriver as you don't want to drop the small torx screws down the back of the dash.
Other than that a good video giving a clear idea of how to do the job. :)
mideos
Wow! Thank you for the detailed advice.
