Kadjar autolocking when walking away
skragamuffin
Unread post by skragamuffin »
hi all i have a 2015 Kadjar and using dtt4all have enabled the autolock feature when you walk away from the car..... this works flawlesly but i dont hear any beeps from the car when it locks i belive this is because it wasnt factory fitted feature and there should be a speaker i think under the skuttle pan i havent looked as yet its too hot tbh but is this a correct assumption and if there is one is this the right location and a part number would be very much appreciated
thanks all for your great help
x 8126
Re: Kadjar autolocking when walking away
I know less about Renaults than you do but I had a hunt around and found someone with similar difficulties. Apparently there is a box under the door sill which has vulnerable plugs which loosen with people getting in and out of the car. I found these which may help you:
"FIXED!!!! I left it in for service with Renault today and mentioned to the service desk. They said to the mechanic and apparently there’s a sensor under the door well kick board. He said that over time people getting in and out of the car have hit it and loosened the plug. He literally plugged it back in again and we’re back to the normal small lock beeps!!"
skragamuffin
just saw your post thank you for that but i had already seen this and nope no go for me i think as it wasnt a factory fit on my car the bleeper is missing and under the skuttle pan theres a free 2 pin plug on the loom so it beggers a question as to say lol
