Faults afternoon changing brake pads
mikeryan
Unread post by mikeryan »
I changed the rear brake pads on a 208 2020 with electric handbrake. I used my launch obd to release the calipers. I had to push the piston back after this. Changed the pads and tries to operate the rear brake but I get 2 codes now. One intermittent is C155D automatic application function inhibited and C1544 electric handbrake inhibited Fse for change of brake pads. I have tried everything I can to rest this but still get the codes. Cana anyone suggest a fix for how to solve the issue.
Cheers Mike
x 8123
Re: Faults afternoon changing brake pads
I think you will need to get a diagbox onto the car and I believe you can tell it that new parts have been fitted and delete the codes. However I have not used diagbox myself for 4 years and there are other members much better qualified to tell you about it. There is a list of members with diagnostics and you may find someone near you: viewtopic.php?p=509922#p509922
If there is a member send them a PrivateMessage and you may get help. :)
x 1489
I would have expected a function to reverse the service mode and put them back in operating mode, no idea what this would appear as on the Launch scanner however...!
