C3 MK1 1.4HDi P0102 issues
AndySan23
Unread post by AndySan23 »
Hi folks having some issues with this code, any help appreciated 👍
Here’s what’s been checked so far :-
Harness continuity from MAF to ECU block connector.
EGR is clean and holds vac.
EGR vac sol works fine and holds vac.
2 x MAF sensors original and 1 from a donor, both giving a reading of 1.86K ohm on pins 2&3 seen some info on web it says 2 - 6 ohms is the norm, so is that correct or is the meter stuffed ?
MAF is a pierburg 7.28342.01
Can clear fault, but returns on every 3rd start of the engine 🤔 very strange but consistent pattern.
Car runs very well, no issues apart from this annoying problem.
Engine code is 8HY
Did have a P0402 previously but that has cleared since I checked EGR and cleaned .
Cheers in advance 👍
Huskyxantia
x 900
Re: C3 MK1 1.4HDi P0102 issues
Unread post by Huskyxantia »
Sounds like not enough air , check any breather pipe or any air related pipes for splits or even kinks , if so take the vacuum pump off and see if that needs a clean.
Common causes include a faulty MAF sensor, wiring or connector issues, a clogged air filter, or an air leak in the intake system.
:-D
