Bloody tipical!!!
np
Bloody tipical!!!
Unread post by np »
Off this evening in our caravan,driving down M5,then steam everywhere.Coming out the back,through the face vents etc.Opens bonnet,the hose that goes into the thermostat housing is off.Get me screw driver out,oh dear o dear.The plastic housing/fitting that the hose pushes onto has snapped.Looks like a very clean break.Hasn`t been touched in over a year,old age i `spose,it also looks very brittle.Will have to try & get 1 in the morning & go to campsite then.
Question:-
I presume this is the same part on Puegeot`s & citroen 1.9td`s???Held on to thermo housing by 3 bolts,10 or 13mm.
PowerLee
Unread post by PowerLee »
It should be the same & you should be able to pick one up from a Peugeot or Citroen dealer ship if they have it in stock.
np
Unread post by np »
I thought it would be.I`ll ring local peugeot dealer in morning as there`ll be cheaper & more friendly than Citroen.If not,i`ll order 1 & see if i can get 1 from the scrappy for now.
np
Unread post by np »
GSF,N17605,THERMOST.HOUSING-PLASTIC
Is that the part i need??Can anyone confirm??I`ll ring in morning anyway,but i know theres a lot of night owls on here.
np
Unread post by np »
£4.50 from Peugeot.All done now,seems ok.Try again now with caravan.Will post again when i get back.
