Citroen C5 RHH engine - injector corection
I have this Citroen
Delphi injection 163 HP
Manual transmission
- o diagbox I can't read corection injection/ it's not active.
All show 1ms.
When I slow down they show value 2 - 3 - or 0.
- injectors are replaced, with manufactured one, before this, the error was tell me that adaptation was outside range.
- I see some air Buble that appear on diesel fuel . Did not find any o-ring replacement.
- x 8165
Re: Citroen C5 RHH engine - injector corection
If you have air bubbles in the diesel then you need to start at the tank and check all the fuel line connections for signs of a leak. If diesel is weeping out then air can get in. Once happy with the lines you'll need to check all around the pump and feeds to the injectors looking for signs of diesel residue. Good luck
