405 le mans non start
nitr0uk
Unread post by nitr0uk »
I have a 1994 Peugeot 405 le mans that has sat for many years and wont start.
It has an immobiliser keypad to which I do not know the code, however when I turn on the ignition the keypad shows a solid green light. The car will crank but wont start.
I also have no central locking functioning. If I press the button on the keyfob nothing happens. Or if I manually lock/unlock the vehicle using the key barrel in the drivers door it only operates the drivers door lock and nothing happens on the central locking.
Any help would be appreciated or anybody more familiar with 405's. Thanks
x 2938
Re: 405 le mans non start
With proof of ownership i.e. the V5 a Peugeot dealer should be able to supply the immobiliser code for the car.
