Citroen C3 - Adblue Problem
Gambit
x 9
Unread post by Gambit »
Hi
Im one of the unfortunate ones with Adblue problems, Im now left with only solution is to change tank.
Im being told by parts suppliers in UK that for it to work and have a waranty it must be fitted by a Citroen Dealer or a PSA approved with the DiagBox as this is needed to start the pump.
Im told that it will not work if I diy change it clear code refill with Adblue.
Some of the info I have seen on this site says DiagBox is available from Amazon - what exactly do I need to order from Amazon?
My choice is a Android V10 Tablet, a Windows V8.1 laptop or a Windows 11 laptop.
What does PSA stand for?
Regards
Gambit
PaulC5
x 670
Re: Citroen C3 - Adblue Problem
Unread post by PaulC5 »
PSA was the Peugeot Citroen group but is now Stellantis. Google AI came up with this
PSA, which stands for Peugeot Société Anonyme, was a French multinational automotive manufacturing company that included Citroën as one of its brands. In 2021, PSA merged with Fiat Chrysler Automobiles to form Stellantis, which is now the parent company of Citroën.
Have a read of this since you might be able to get a bit of money out of Citroen viewtopic.php?t=85001
Something else to read viewtopic.php?t=81429
If you have not had your air bags replaced then read this since Stellantis are telling owners of C3s and DS3s not to use them until replaced viewtopic.php?t=86622
