Citroen dispatch mk2 2.0D air con pipes
bitsas004
Unread post by bitsas004 »
Bottom rad pipe end broke of when removing from old radiator, in this diagram the pipe is shown nr4, it is connected to the whole pipe which is nr2 where it bulges a little, i was hopping that it can be replaced just the shorter bit (nr2) and not the whole pipe. Anyone have any ideas if anyone fixes things like this or know the part number for pipes ?
x 8128
Re: Citroen dispatch mk2 2.0D air con pipes
I believe the pipe you are after is in the middle of this bundle on ebay: https://www.ebay.co.uk/itm/292252157736 ... R7b8-_z9ZQ :)
