xantia rear height problems
dannyvale
Unread post by dannyvale »
I had noticed that when I start up my 94 xantia, the rear would not rise. After inspecting the underneath, there is a little hook attatched to the roll bar joined to a plastic link for the height valve. This had parted from the roll bar. After putting on a new one, the rear still fails to rise. Could someone please tell me how to correct this problem.
Many thanks,
danny.
ds23
Unread post by ds23 »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dannyvale</i>
Many thanks,
danny.
You probably have problem with siezin bushes in the rear height correction assembly. The sad thing is that they are riveted in place.
Check this webpage for the pictures. Can you read swedish? Even better!
http://medlem.spray.se/xm94/XANTIA/ren_lank.html
OK it mainly concerns the activa linkage but what the guy is doing to the activa linkage he has alreddy done to the heigh correction.
