308 AdBlue Tank Coding
dsgoody
Unread post by dsgoody »
Hi all,
I originally posted here (viewtopic.php?p=841670#p841670) assessing my options for a replacement or AdBlue tank fix. I ended up picking up a cheap second hand tank from a similar age car, since right now I don't have the time to be fiddling around with pressure sensors.
I've fitted the tank, fired up Diagbox 9.150 and when selecting to option to tell the car it's had a replacement AdBlue tank all I get is;
Conditions of execution not satisfied
Follow the procedure below:
- Start the operation again
- In the event of reoccurrence, contact the technical assistance platform.
I have keyless entry, so I have placed the key in the reader in front the the OBD port, but this has made no difference.
Any suggestions? A quick Google seems to indicate this might be because this is a telecoding function; which I'm surprised by when the third party tools seem to do it do problem (like in the O'Rileys Autos video). It seems unless I spend thousands in diagnostic tools, I'm always going to be missing some functionality.
Does anyone have a solution?
Cheers.
Apurpleproblem
Re: 308 AdBlue Tank Coding
Unread post by Apurpleproblem »
I had a few goes at doing this with my DS 3, I’m sure it wants you to do a test on the system and you can also bleed the system in diagbox, then tried recoding using “Repair” then into Reinislised of the AdBlue systems…
LedZep
x 30
Unread post by LedZep »
dsgoody wrote: 21 Jun 2025, 17:01 I've fitted the tank, fired up Diagbox 9.150 and when selecting to option to tell the car it's had a replacement AdBlue tank all I get is;
I've noticed in some occasions that trying different version of Diagbox, does the job.At least for my car model. Currently i'm using 9.186 with no problems.For example, with 9.150 ver. i couldn't reset the gearbox wear counter.So, give it a try.
dsgoody
An update to 9.186 has resolved my issues, thanks. I think this might be my new favourite version, since it reliably clears the engine codes as well (previously I had to use FAPLite for this).
It remains to be seen if my AdBlue tank is actually working or not, but it is now coded to the car and I can read values from it with no error codes about a missing tank.
