External sensor and AC problem. Possibly TPMS as well?!
jcknowles
Unread post by jcknowles »
Hi
On our DS3 the external sensors was reading very low (-25 to -30). Also the AC wasnt working. Also TPMS was giving errors for all 4 tyres. Took it in to be regassed for the AC and the engineer said the compressor wasnt coming on.
After a bit of online reading I thought it might be due to a broken external air temperature sensor. Changed it and it seemed to be reading a better air temperature, although it was still wrong (reading 10C instead of 20C). Subsequently the temperature reading went back down to -25 to -30.
Does anybody have any ideas what might be the cause of this? Is there a central control unit that might be the source and where is it located?
Thanks!
Jonathan
x 1939
Re: External sensor and AC problem. Possibly TPMS as well?!
Unread post by Paul-R »
Where did you get your replacement temperature sensor from?
jcknowles
Hi. Thanks for the quick reply. From ebay. Is it likely to be a cheap part? Should I have got a genuine one?
Thanks again
