4HP20 Breakdown: Swap, restore, interchange?
Angles and Lions
x 3
Unread post by Angles and Lions »
My trusty old 607 just lost its ability to move.
After 345000 kilometers, the transmission gave up.
There has been signs;
- First, a slight judder when driving approx. 50 km/h with a light foot on the gas,
- followed by moaning, croaking noise coming from the oil pump / converter area while idling,
- culminating with no movement at all in drive, reverse and manual (which displayed "M4" no matter what I tried to select).
I left it to cool down overnight, and the morning after, I started the car, and tried R, N, D. It moved, long enough for me to roll the 20 meters to my garage door. The pump was still moanin' along.
Got the car on my lift, and let it warm up to 60°c, unscrewed the level plug and approx. 100 ml. oil came out. OK, it wasn't oil starvation.
Stopped the engine and drained the transmission.
Oil smelled like LT11741, although with a sour, burnt scent as well. It was black, with a slight grey shadow, which was enough for me to conclude it was time to contemplate my possibilities.
Here in Denmark, only one junkyard has a V6 transmission for sale. It has 280.000 km. on it, and therefore not an option.
A rebuilder quoted me DKK 27.000 (£2100) to rebuild my unit... not an option either.
Then, another possible solution came... or?
A private seller has a 4HP20 transmission from a 2004-model with the same engine as mine (ES9J4S), but the plate on the seller's transmission says 20HZ24, while mine is a 20HZ10.
The seller has the rest of the car as well, only 180.000 km on it, which seem to be the way to go.
But, I am in doubt if it will be plug and play, since the difference between 20HZ10 and 20HZ24 must mean something. I have read a lot on several forums about the various 4HP20-transmissions, that are found in Citroëns and Peugeots of this vintage (1999-2005), and learned that there are different gearing, diesel/petrol versions, and so on. I have searched high and low for an overview of some sort, but haven't had luck yet.
Is there anyone who can tell me, what the types 20HZ10 and 20HZ24 means?
Are there other possibilities to choose from, when sourcing a transmission for my beloved old car?
And, is it possible to pull the transmission without having to remove the engine as well? As far as i see, there may be room...
I have read the disassembly guide made by @citrojim, and I am up to try restoring my old transmission to build a spare, but right now, my priority is to get it back on the road.
Cheers,
Johan
x 8422
Re: 4HP20 Breakdown: Swap, restore, interchange?
Hi John, sorry to hear you have a dead 4HP20 :( I have lots of experience with these and you may wish to consider a rebuild, perhaps using parts from the good donor you have found.
Here's a guide on rebuilding one: https://www.eastment.net/4hp20/4hp20_introduction.htm
Whatever you do, have the torque converter rebuilt professionally as the breakup of the lockup clutch inside the torque converter is often the cause of the gearbox failure. Particles of friction material from its clutch plate clog the oil filter which in turn reduces oil (hydraulic) pressure and leads to slipping clutches/brakes and oil starvation - hence the LT71141 smelling burned.
Generally, they're not 'plug and play' and I found that to my cost after my first rebuild. In some cases a transplant from one car to another is possible if you use the ECU that matches the gearbox so if you take the gearbox from the donor complete with its ECU then it's likely it will be OK. In any case the ECU must be matched/paired to the gearbox via the reinitialisation routines in Lexia/Diagbox.
Keep us posted on progress...
x 1472
Unread post by xantia_v6 »
If the one with 280,000 km is cheap and the same part number, it would probably be good for spares, as yours has probably destroyed the oil pump and maybe burned a clutch pack.
In normal use these transmissions would go forever if it wasn't for the torque converter clutch and the filter.
If considering swapping the transmission and ECU from another model, beware that the ECU must also be compatible with the electrical architecture of your car, which changed every few years.
Angles and Lions
x 3
CitroJim and xantia_v6, thank you for your replies.
A little status;
There's a friendly chap in the spares department at a Peugeot dealership here in Denmark, he is currently investigating the 20HZ10 / 20HZ24-mystery by checking the VINs on the two cars, if any upgrades on the newer makes it "impossible" to switch over.
This is a learning process for me as well as a repair job (:
I will update, soon as i get some Intel from the spares guy.
Angles and Lions
x 3
Hello again,
Time for another update.
Been away from the garage for a while - but for the last two days, i've managed to disassemble a good bit. My plan is to take the transmission out from underneath, after removing the front crossmember.
The spares guy from Peugeot told me, that the two transmissions had the same spare part number, so according to him, it should switch over, no problem.
Now for another question;
Is it possible to replace the filter without having to split the box completely? I.e. removing the valve body, or the oil pump? (There was a rubber gasket for the valve body in the filter "kit").
x 1472
No, sadly there is no way to replace the filter without splitting the transmission case, disassembly to that point is time consuming, but possible, see Jim's web pages linked earlier.
Angles and Lions
x 3
Thanks, xantia_v6,
I'll postpone the filter change, and see how the new-used transmission behaves first. With only 180.000 kms, oil is clear and doesn't smell burnt.
So, an oil change it is.
Got the front crossmember down without much hassle, and with the engine suspended from above, the transmission could be unbolted from the engine.
First the three converter bolts, then the bolts that holds the transmission to the engine.
Before loading the new-used transmission on, I noticed that the speedometer drive on it was not there - instead there was a plug. Took that out, and to my pleasant surprise, the ring gear for the drive was still there. They may have left it in for use in vehicles without it (I guess that they took the speedometer signal from the ABS on later models).
Now the transmission hangs proudly on the engine.
Still more assembly left. Will post update.
Angles and Lions
x 3
Good news. It works!
After assembling it all and refilling it, I started up and tried the gears. Shifted abruptly from N to D, R and when in manual mode, nothing. Shut it off and changed the transmission computer to the one that came with the "new" transmission. Power on, and then it all worked perfectly. Drives and shifts smoothly, surely a big difference.
Summary for others in my situation:
- Yes, it is possible to get it to work with a 20HZ24 from a 2004, when having an early car with a 20HZ10 in it.
Just make sure that you get the computer from the same car as the donor transmission.
- This 20HZ24 did not have a speedometer drive, instead there was a plastic plug. The ring gear is still inside, though, so you just remove the plug and drop your drive in from your old 20HZ10.
All other connections were the same on the two units.
- The task is a bit involved, as the front crossmember has to come off, and the transmission lowered. But not impossible.
Thanks for the helpful tips I had here.
x 8422
That's absolutely excellent news :D Well done!
If you have access to Lexia or Diagbox, it would be interesting to try the old ECU (computer) again and execute the reinitialisation routine. It just may work then as the initial intialisation routine 'locks' or 'pairs' the computer to the gearbox. An unpaired 'box and computer will do exactly as you describe.
wurlycorner
x 271
Unread post by wurlycorner »
Excellent news, well done!
Iain
CX DTR T2 Safari (silver)
