5008 1.6hdi blower not blowing
Pug5008
Unread post by Pug5008 »
Hiya I hope Yr all well and having a great week
I have a 5008 1.6hdi manual that I have just changed the battery, gearbox oil and nr side ball joint on and since then the heater/air-conditioning blower has ceased to work I have pulled out half the dashboard to gain easier assess to the passenger footwell fuse board and the drivers side blower. The blower has two lots of wires going to it a pair that have no voltage and a block of 4 I have 4.7v on one wire when I turn the fan switch the others are making the probe lightly glow so there seems to be a uber low voltage as its not registering a proper voltage would anyone have or be able to explain the wiring harness for the blower please and maybe tge wire numbers I should be checking as I'm currently stumped oh and where the resistor is
Thank you for any and all help give it is truely appreciated
x 8126
Re: 5008 1.6hdi blower not blowing
Unfortunately we do not have access to the Stellantis databases at the moment so cannot find the diagram for you, however you may get some guidance from this site:
https://www.wheelsjoint.com/peugeot-500 ... diagnosis/
