Dispatch 2021
Ingy1
Dispatch 2021
Unread post by Ingy1 »
Can a steering wheel from a Dispatch Driver Pro (the one with all the steering wheel button controls) be fitted to a Driver model that has a plain wheel?
If so is it just a straightforward swap over without any massive electrical rewiring work?
Ingy1
Re: Dispatch 2021
Thanks for all the help.......Not !!
x 5681
Re: Dispatch 2021
Bear in mind that this is not a dealer or professional service, just a lot of like minded owners sharing their collective knowledge and not all are online all the time. It can take weeks before someone who has an answer sees your post and can advise you.
x 1060
Re: Dispatch 2021
Unread post by wheeler »
As you didn't get any replies I'm guessing no on knows the answer or done the conversion. I had never even seen a Dispatch with buttons on the actual steering wheel (only on the separate stalk) until i just googled it.
At a guess you may also need to change the comms unit (the lighting & wiper stalk assembly) also & would most likely need some configurations changing in the BSI.
As i say it is just a guess as i had never even seen the system.
