206 cc Climatronic not working
stilpet
Hello I have 2005 Peugeot 206 cc with climatronic. The blower heater is not working. The motor works when given 12v directly but not when connected to the wiring connector. I have 3 resistor modules which control the blower speed that I tested and it still doesn't work. All fuses are OK. There is no power coming to the blower connector (red and black wires). Can someone post a schematic/wiring diagram with color codes? I read that the blower is controlled by the BSM BH34 in the engine compartment and the BSI inside the car fuse box. Does it have a relay? Thank you.
- x 8122
Re: 206 cc Climatronic not working
I'm sorry you had no replies to your query. Have you resolved this problem yet? If so could you add your result for the benefit of others?
