DS3 2012 heater blower stopped working..SOLVED
ashn
Unread post by ashn »
hello,
this is my 1st post and looking for any help.
Heater blower has stopped working, on any setting.
checked:
Fuse (and terminals for corrosion)
Motor
Resistor. all ok.
i know its the ground wire thats switched so checked the Voltage at the fan connector live terminal, im getting fluctuations from 4.5 to 6v. this is where i think the problem is.
any ideas or has anyone had this before?
many thanks.
PaulC5
x 717
Re: DS3 2012 heater blower stopped working....
Unread post by PaulC5 »
When you fit the new resistor pack, was it one from a Citroen dealer, one from the same manufacturer or a copy part ?
ashn
thanks for your reply, but i found the problem, its an issue in the BSM, i found this thread and its now working viewtopic.php?t=56694&start=15
