peugeot 508 CAN problem ?
barteczekk
Hello. The car is a Peugeot 508 SW 2.0 HDI 163HP from 2011. The gearbox stopped working in the car. It was repaired. The car has driven about 150 km after the repair. The problem is that the car changes gears for about 1 minute. Then the gearbox shifts from D1 to D5 and that's the end of the drive. The last time I was able to scan all the modules in it using x431 was in January. The report is attached. Now x431 does not find BSI and many other modules, in fact it probably only sees the gearbox and the rain sensor. After connecting Diagbox 9.150 it finds all the modules but they are full of CAN communication errors. u1213 u1109, u1209, p2711, it looks a bit like the car is driving until the CAN network goes crazy. I checked the resistance of the gearbox controller, power steering, bsi, abs, ecu, everywhere 60 ohms. I checked the cables, resistance 0.5 ohms. I tried disconnecting subsequent modules to get the possibility of using x431i scanning the entire system again. So far without success. I replaced the BSM with a used one but no change.
- Attachments
[The extension rar has been deactivated and can no longer be displayed.]
barteczekk
Re: peugeot 508 CAN problem ?
I find the problem with communication. Pin nr8 in obd2 socket was unpluged. Its Can L diag according to obd2 schema for pug. Now i find problem w gearbox witch give me dtc p0765 or p0761.
Doom
- x 15
Hi, are you sure that they correctly assembly your gearbox after repair? I'm asking as you have 2 errors from 2 solenoids, I have such issue in the past, someone put wrong solenoid to the wrong place. It was different gearbox but maybe you have similar issue.
barteczekk
This 2 dtc no comes together. once when i delete dtc is 0765 once 0761. I need to know how to check oil pressure ? Converter was replaced by refubrishment one not new one.
barteczekk
Yes but this dtc not coming together. Im not even sure it possible to chnge selenoids with pleace.
