C4 Grand Picasso Clutch Issue
Delvey
x 6
Unread post by Delvey »
Good afternoon
Over the weekend my misses experienced a clutch pedal dropping to the floor with it not returning.
It is a 2010 1.6 HDI Grand Picasso with the 5 gear box.
On initial inspection I changed the clutch slave cyclinder as it appeared to be leaking fluid. However, the system is still leaking fluid and the clutch is not operating on the lever next to the gear box (basically where the slave cyclinder sits). Is there another cyclinder inside the gearbox that could be leaking?
PaulC5
x 682
Re: C4 Grand Picasso Clutch Issue
Unread post by PaulC5 »
Have you checked the master cylinder in case that is leaking, most likely seen in the footwell ?
