Renault Captur fault code 156013
LazLon
New User
Unread post by LazLon »
I am getting an intermittent dashboard warning 'Engine Failure Hazard' and the stop light. Car drives well. According to TOPDON diagnostics, the error code is 156013 (Oil pump solenoid valve Open circuit). Is the fault likely to be the valve or the sensor?. What's the recommended action.
Thanks.
Laz
notinserviceuk
x 5
Re: Renault Captur fault code 156013
Unread post by notinserviceuk »
error code 156013 indicates a "Solenoid valve of the oil pump Open circuit" fault, which is related to the engine's oil pump system.
This issue has been reported by owners of Renault Captur models, particularly the 0.9 Tce 90 Dynamique S Medianav Energy 2015 variant, where an intermittent warning "Risk of engine failure" and a stop light appear on the dashboard.
The fault is typically not due to the solenoid valve or sensor itself but has been traced to a defective wire.
The recommended action involves diagnosing and repairing the wiring issue.
