Kangoo Side door lock cable replacement
Ric Ochet
(Donor 2022)
x 3
Unread post by Ric Ochet »
Does anyone know if the bowden cable of the side door lock of a 2011 Kangoo can be replaced? I had a quick look inside the lock and it looked like it was bonded into the actuating arm but I've since seen the cable offered as a separate item. I'm just not sure if this will work for a 2011 or whether it was for a different version. It's not my van so I wasn't able to fully take it apart as the owner needed it and without the lock there was no way of keeping the door closed.
Huskyxantia
x 868
Re: Kangoo Side door lock cable replacement
Unread post by Huskyxantia »
:-D
