2010 Nemo top mounts
ohspecial1
Unread post by ohspecial1 »
Hi Folks
Got the Garage to change top mounts about a coupleof years ago max only had the car 3
Now are starting to knock again
Am i guessing because of the design like grill where the wipers are the water goes straight down the holes on the top of the bearing
Was there a fix or just replace every 2 years
Garage charged 4 hours labour last time
Huskyxantia
x 904
Re: 2010 Nemo top mounts
Unread post by Huskyxantia »
They should last longer that that , if there using cheap parts then that might be the issue, if you know there's a water problem then see if you can do something to stop the water causing damage , if possible use clear mastic to create a stop so water hits that and runs the lenght of the bead away from the mount
:-D
