Peugeot 308 T7 2010 sometimes won’t start
Mario ashraf
Sometimes when I’m driving in low speed the car just turns off i put it in N and it just turns on again, yesterday I tried to turn it on in the morning and it was just cranking with no start, after several attempts it started i drove for like an hour, parked for like 10 minutes and then tried to turn it on again and didn’t start after so many attempts it started for 10 seconds and then turned off again after several more attempts it finally started drove to my house and then today morning started with no problems but since then it’s always idling in 900 RPM instead of 800 as usual but while driving the car is completely normal and smooth, In the OBD it’s giving me problems with the 4 injectors and a P000A fault and U1313 Why is that happening? Can it be the fuel pump?
Huskyxantia
- x 904
Re: Peugeot 308 T7 2010 sometimes won’t start
U1313 is no connection to ecu fault , have you hit a pothole at all ? If you can locate your ecu then see if all connections are as they should be the other code is something to do with the camshaft sensor and sometimes an out of alignment issue , that's all I can help with there.
Husky.
