I have previously posted that I had issue with the rear washer activating the front, and was quite rightly told that the flapper unit failed. As such, I replaced the pump for a new one.
The new one is weak, which makes me think that I have a bad motor, but before I go trying to replace it again, I wonder if anyone here has fixed low pressure from the washers. I have changed the nozzles, as there was a blockage in the one side that I couldn't clear out.
Or, if someone else has had to change the washer pump, could you let me know the model you got? I wonder if I just got a crap aftermarket one that isn't powerful enough.
C3 2017 pump is weak
- x 8130
Re: C3 2017 pump is weak
Did you get this resolved?
