Citroen jumpy U6U 1998 1.9 td How to remove power steering pump to reach and remove fuel pump?
Jumpyer 98
Unread post by Jumpyer 98 »
Hello! I have leak in my fuel pump and im going to give it a try to remove the Bosch fuel injection pump and replace most of the orings sealings. ( Even if I just suspect the big o-ring in the pump head)
Its pretty small space under the bonnet under this French car. I have been spending hours to remove fuel lines wires etc.
Anyway there are three bolts at the front and one at the rear of the fuel pump.
How can i easy remove or at least tilt the steering pump a little bit so i can reach the bottom nut/ bolt that holding the fuel injection pump to the engine. ?
I have images but dont know if its possible to post them here .
Thanks Citroen jumpy 1998 1.9 td
x 5672
Re: Citroen jumpy U6U 1998 1.9 td How to remove power steering pump to reach and remove fuel pump?
See your PMs for advice on image posting.
