peugeot 5008 Eolyse problem.
christianjensen5001
Unread post by christianjensen5001 »
Hi
i have a Peugeot 5008 1.6 hdi 120.
previous owner ran the eolyse tank dry.
it gave me these errors
P1434:96 multiplexed additive pump- fault in multiplexed pump
and
P1435:00 multiplexed additive pump - can fault or multiplexed additive pump fault.
so i bought a new tank/pump and i filled it with eolyse.
i tried to adapt the new pump but with no luck. i still cant hear the pump runing when i activate it.
does anybody have a wire diragram over the eolyse pump supply? i would appriciate that :)
the Vin is: VF3**************[VIN obfuscated, can be read by forum staff]
i used diagbox and autel both with the same error
best regards
Christian
x 1943
Re: peugeot 5008 Eolyse problem.
Unread post by Paul-R »
Was the Diagbox a full chip type? What version of the Diagbox software are you running?
christianjensen5001
Paul-R wrote: 07 May 2025, 10:16 Was the Diagbox a full chip type? What version of the Diagbox software are you running?
Its full chips and its version 9.98
