Torque for plastic thermostat housing? 207 1.4 kfw engine
Yewboy69
x 3
Unread post by Yewboy69 »
As title, does anybody know the correct torque for the plastic thermostat housing on a 2012 Peugeot 207 1.4 petrol kfw engine?
I'm having issues getting mine to seal properly but don't want to overtighten it!
Thanks in advance!
Arkis
x 27
Re: Torque for plastic thermostat housing? 207 1.4 kfw engine
Unread post by Arkis »
There is actually no seal on the plastic housing. Only seal is on the thermostat itself (rubber edge on the thermostat body). Check if it is not cracked or slipped.
Sorry, no torque value found. I just do it snug enough so there is no gap in between.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
PaulC5
x 682
Unread post by PaulC5 »
If it is the complete housing as in this ebay link, it shows a blue seal. https://www.ebay.co.uk/itm/254636470734 ... %28TU3A%29
In the Haynes manual for the C4 to 2010 it gives the torque as 10 Nm for a similar housing but yours might be different. Do the bolts up evenly to make sure the housing is flat against the head and also check for any damage of the mating surfaces.
