Washer jets not working (C4 GP 2017)
Glaede
Unread post by Glaede »
I just purchased a C4 Grand Picasso 1.6D 120HP from 11/2017, but I'm having some issues with the washer jets.
The washer fluid motor doesn't run when I try to clean my front or back window. Sometimes, however, the front light jets works (which I'm sure is the correct behavior).
At the same time I get a "service light" warning and a text that says that I need to fill up the washer reservoir (which I have done twice). I see no spilling, so I don't expect it to drain. It seems like an electrical issue.
Has anyone experienced this before? No washing AND at the same time a warning about low level of fluid?
Could it be a dead washer fluid motor or maybe a bad levelling sensor?
Thanks!
P.S. I'm new into french cars - more into the german stuff ;-)
Kind regards!
Søren, Denmark
x 1488
Re: Washer jets not working (C4 GP 2017)
You'll need to get in to the pump to see there is power to it. The headlamps use a separate pump.
x 5671
Perhaps the low level sensor cuts power to the motor to save it burning out.
Maybe detaching the sensor wires will allow it to work, depending on how it operates.
Glaede
myglaren wrote: 30 Apr 2025, 19:04 Perhaps the low level sensor cuts power to the motor to save it burning out.
If have been thinking the same. Anyone knows where the sensor is located?
Glaede
RichardW wrote: 30 Apr 2025, 18:31 You'll need to get in to the pump to see there is power to it. The headlamps use a separate pump.
Thanks for clarifying that. I suspected that. I’ll definitely try to measure the power at the pump, just haven’t had time. I hoped this was a basic/known issue 😊
