Good morning Everyone,
Please can you help me with my daughters 2014 Peugeot 208 1.2
I changed the lower wishbones yesterday and lost some gearbox oil, not a lot but I would like to drain and refill.
How do I do this?
I think I’ve found the drain, but how do I refill?
Also what oil do I need?
Puegoet 208 Gearbox oil
Huskyxantia
- x 908
Re: Puegoet 208 Gearbox oil
Top of bearboxsome have what looks like a black plastic nut 17mm with a piece that sticks up , some just a hole , 1.5 litre might be enough someone else on here can correct me , that part that sticks up on this nut is what the tube of the refill bottle pushes onto , then there's boxes that have the refill nut on the side which is easy located it undo it if its full it will come out so do it slowly if it don't come out top it up till it does , gear box oil refill bottles come with a pipe , see link for what's what
Husky.
Huskyxantia
- x 908
Huskyxantia wrote: 19 Mar 2026, 21:23 Top of gearbox some have what looks like a black plastic nut 17mm with a piece that sticks up , some just a hole , 1.5 litre might be enough someone else on here can correct me , that part that sticks up on this nut is what the tube of the refill bottle pushes onto , then there's boxes that have the refill nut on the side which is easy located it undo it if its full it will come out so do it slowly if it don't come out top it up till it does , gear box oil refill bottles come with a pipe , see link for what's what
Husky.
