VIN decode
rickya
VIN decode
Unread post by rickya »
I’ve seen on a FB group that you guys are able to decode VIN ninbers, is this still a thing? I don’t mind donating. I’m getting fed up of looking for parts and having several different options!
I have a 2014 C4GP.
x 1044
Re: VIN decode
Unread post by wheeler »
Whats your VIN
rickya
Re: VIN decode
x 1044
Re: VIN decode
Vehicle characteristics
Vehicle family C4 PICASSO / C4 SPACETOURER (B78)
AS/RP N° 13898 FV 2 0275
Warranty Start Date 15/12/2014
Engine serial number 10 JBEX 3048716
OPB 0030
BER e2*2007/46*0356*08
P4A 9801889699
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C4 PICASSO / C4 SPACETOURER (B78)
SILHOUETTE ESTATE - LEISURE
TRIM LEVEL HIGH HIGH
ENGINE DV6C TURBO DIESEL
TRANSMISSION STT 6-SPEED PILOTED MANUAL GEARBOX
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR KTP - SHARK GREY PAINT
INTERIOR TRIM TYPE TRIM.FINN VELOUR "1H"
UPHOLSTERY COLOUR "FR"
GEARBOX (CHARACTERISTICS) MCD MANUAL GEARBOX
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) DV TYPE ENGINE
OTHER BADGE, " MISC. " EXCLUSIVE
BADGE WITHOUT BADGE
STEERING VARIABLE POWER STEERING
SPEEDOMETER DRIVE WITHOUT SPEEDOMETER RATIO
Fuel supply-Engine
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 5 L6 UPPER ENGINE EMISSION CONTROL
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY 1600 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER BELOW 50PPM
FUEL TANK FUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTION OPTIMISED FUEL CONSUMPTION
COOLING MOTOR RADIATOR 28DM2-18F1
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION) EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 2-SPEED FAN 95W AERO
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITH STOP AND START ALTERNATOR STARTER
Gearbox Transmission
FINAL DRIVE RATIO CP 19 X 74
WHEEL STYLE 17-INCH AQUILLON GREY ALLOY WHEEL 7 J17 CH 5-50
CLUTCH WITHOUT CLUTCH
RIM/TYRE SIZE 17 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 205/55 R17 95V REINFORCED TYRE
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
GEARBOX TYPE MC MANUAL GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
STEERING COLUMN MANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR DIAMETER 23 HOLLOW
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORNS-HARMONY
AERIAL ROOF AERIAL + GPS + DIGITAL + INTEGRATED
SIDE MOULDINGS (DIMENSION) WITHOUT SIDE PROTECTOR, WITH CHROME SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
INDICATORS SIDE MARKER LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
DRAUGHT EXCLUSION FR AND RR DOOR AERODYNAMIC SEALING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR
ENGINE BAY SOUNDPROOFING SOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN
WINDSCREEN WIPER 2 SPEED INTERMITTENT+AUTOMATIC CADENCING
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF GLASS WITH ROOF WINDOW
BUMPER B COL FR BUMPER+CHROMED STRIP AND B COL RR BUMPER
NUMBER PLATE WITHOUT LICENCE PLATE
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FOG LAMPS WITH CORNERING LIGHT
PANORAMIC VISUAL AID WITHOUT PANORAMIC VISUAL AID
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES EXT HANDLE BLACK + CHROME RING
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) WITHOUT EXTERIOR MIRROR SPECIAL FEATURE
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN
HANDS FREE ACCESS AND STARTING FRONT ACCESS + BOOT + HANDS FREE STARTING
Interior fittings
ANTI-THEFT ALARM WITH THEFT PROTECTION ALARM
REAR HEAD RESTRAINT SLEEP HINGED REAR HEAD RESTRAINT
FRONT HEAD RESTRAINT SLEEP HINGED FRONT HEAD RESTRAINT
SUPPLEMENTARY SEAT 2 PLACES SUPPLEMENT SEPAR SEATS
BLIND SPOT DETECTION WITH BLIND SPOT MONITORING
LUGGAGE COVER LUGGAGE COVER + WINDSTOP
REAR SEATBELT RR SEAT BELT 5 INERT REELS 3 PTS + FASTEN WARN LGH
FRONT SEATBELT REVERSIBLE REEL + DRIVER AND PASSENGER ALARM
ASHTRAY WITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP) HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONING WITH HEATER MATRIX
SPEED GRADUATIONS SPEED GRADUATION IN MPH
GEAR SELECTOR GEAR CONTROL AT THE STEERING WHEEL
CONSOLE WITH REMOVABLE CONSOLE
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
AIR EXTRACTOR STANDARD AIR EXTRACTOR
LOAD SPACE LIGHTING WITH GLOVEBOX LIGHTING
BOOT AND LOAD SPACE LIGHTING BOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENT EXCLUSIVE DASHBOARD DECORATION
INT. TRIM AND EQUIPMENT VARIATION CLOTH INTERIOR EQUIPMENT TRIM
MISC. INT. LAMPS LIGHTING BY LEDS
WORK TABLE WITH WORK TABLE
LOAD SPACE TRIM BOOT CARPET MAT
UNDERSEAT STORAGE 1 UNDER SEAT STORAGE DRAWER
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
DOOR TRIM DECOR GLOSS VARNISH
ADDITIONAL BLOWER WITH ADDITIONAL PULSE
PASSENGER COMPARTMENT SOUNDPROOFING SOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT ADJUSTMENT PASSENGER SPACER
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL FRONT SEAT CONTROL MANUAL + RELAX
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT FOLDING WITH FOLD PASS FRONT SEATING
FRONT SEAT ARMREST DRIVER ANT PASSENGER FRONT ARMREST
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN FLAPS IN FLOOR
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS HALOGEN BULB
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DISPLAY DGT TOUCHSCREEN+12" DFT DISPLAY
OIL GAUGE W/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER’S FOOTWELL + DOOR TRIM PAD LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
ELECTRIC WINDOW (OPERATION) DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
COURTESY LAMP CONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
RADIO RECEIVER SMEG DIGITAL RADIO RECEIVER
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL CRUISE CONTROL SPEED LIMITER DISTANCE MAINTAINING INHIBITING BY THE CUSTOMER
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS) NET SEAT BACK STORAGE POCKET
CARPET COVER CARPET MAT 1
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
OBSTACLE DETECTION SYSTEM FR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK
LATERAL BLINDS SIDE BLINDS
TRIM ADAPTATION KNOB PVC + CHROME DISC + GAITER IN PVC SURPI
FLOOR MAT FR + RR MATS
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL LEATHER STEER WHEEL 4 BRANCHS
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
REAR VIDEO SCREEN WITHOUT REAR VIDEO SCREEN
CHILD OBSERVATION INTERIOR MIRROR INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET 1 JACK PLUG + 2 USB
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Electrical
ALTERNATOR ALTERNATOR ISTT51
HORNS HORNS-HARMONY
BATTERY BATTERY L3 760 SEALED(L3 760 VRLA 760 EN AGM)
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING FRONT DAY RUNNING LIGHT (DRL)
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
MULTIPLEXING FULL ELECTRICAL ARCHITECTURE
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
MODIF. DURING MODEL YEAR 3RD MINOR MODIFICATION
CONDENSER (SPECIFICATIONS) CONDENSER 19,3DM2 THICKNESS 12
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES IHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET TRIPLE ACCESSORIES SOCKET
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
Glaede
Re: VIN decode
Unread post by Glaede »
wheeler wrote: 27 Apr 2025, 22:43 Can you decode this VIN as well?
Thanks!
