C4 Picasso blower motor location
Patur
x 3
Unread post by Patur »
Good day, I have a Citroen Picasso PT130, first registration was in the year 2017. We drive on the right hand side, steering wheel on the left. I've been told the most likely location for the climate blower motor is on the passenger side, under the glove compartment, but I cannot get a clear enough visual to confirm. Does anyone know? And should I perhaps remove the glovebox to get access to the motor?
uzigon
x 4
Re: C4 Picasso blower motor location
Unread post by uzigon »
I have a 2010 C4 Grand Picasso and it was on the right side of the vehicle (steering wheel also on right), I had to remove quite a few panels to access it. If your's is anything like the older C4GP this video might be useful.
Patur
x 3
For anyone wondering, it turns out I had to remove the glovebox which also required me to pry open the centre panel. Once you've got room and access to the motor, replacing is straight forward
PaulC5
x 681
Unread post by PaulC5 »
Good to know this. Did replacing the blower fix a problem you had and if so what was the problem ?
Patur
x 3
PaulC5 wrote: 30 Apr 2025, 13:40 Good to know this. Did replacing the blower fix a problem you had and if so what was the problem ?
The blower motor just stopped working one day. I replace it with a brand new one.
