Hi guys,
I need ideas, and i saw other similar topics, but no solutions. So the thing is that i was changing the bulb in sun shader (ceiling mirrors) and as bulbs are small i was using pincers and got a short cirtuit.
After this, starting a car caused many faults:
1. Under inflation monitoring fault
2. Power Steering faulty
3. ESP / ASR system faulty
3. The following dash lights are on Steering, tire inflation, service and ESP
4. The power steering also doesn't work.
I have already checked seperately all the fuses (under the steering, under the hood) and all of them are OK.
Please give some ideas, or if anybody knows a solution.
C-Elysee / DS3 Many faults after short cirtuit
PaulC5
- x 688
Re: C-Elysee / DS3 Many faults after short cirtuit
Check the battery voltage since if low it could give these apparent faults without them actually being faulty. If fully charged it should be 12.7 volts before the first engine start of the day. If below about 12.5 volts it needs charging up.
Sieras206
Thanks, i will check. But don't you think this can be related to short cirtuit (faults). Here person had same problems but no solution
: viewtopic.php?t=71117&fbclid=IwY2xjawJ0 ... _qP6h65WpQ
Sieras206
Guys, any ideas? can't find the problem.
PaulC5
- x 688
What was the battery voltage ? You will need a diagnostic to check the abs sensors since there could be a faulty one or its wiring might have a fault.
