Fault
Ldd43
Fault
Unread post by Ldd43 »
I have 2015 Citroen c4 grand Picasso and it as fault code p13c200 and how do I get it fixed and can I buy a rear number plate wiring loom because the bulb holder as broken and the bulb and only one light works
malc4
x 3
Re: Fault
Unread post by malc4 »
check battery?
Ldd43
Re: Fault
The battery as been checked anything else to check
PaulC5
x 686
Re: Fault
Unread post by PaulC5 »
You should check at a Citroen dealer for a new wiring loom and a bulb holder. Other option would be to try a car breakers. If you check the existing wiring it might be broken between the tailgate and the body if you think the wiring has a fault.
A search on the fault code came up with an identical topic (yours ?) on face book with a reply of things that should be checked from what I think is a diagnostic printout.
