3008 GT line 2019
Evansdan81
3008 GT line 2019
Unread post by Evansdan81 »
Heater has completely stopped working have changed the resistor and the motor but still don't don't have and heating has anyone had this problem and did you solve it
Arkis
x 27
Re: 3008 GT line 2019
Unread post by Arkis »
Is coolant flowing via the interior radiator? On my C4 Picasso there was quite common problem that when the coolant was not maintained (recommended changing every 5 years or 50 000 km) it can gunk up the radiator which has really small channels in it. Rust and dirt from coolant system will block it = no water flow = no heating.
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
Evansdan81
We can feel warm air coming from the vents so the car is heating up it's the blower motor that doesn't do anything, turn on the fan and nothing
